I am having problems with BSODs and random restarts when running my memory at 1066 MHz. It is the F2-8500CL5D-4GBPK and my motherboard is the ASUS P5E Deluxe. At 800 MHz ram speed, I have had up times of well over 4 months at a time, but at 1066, I get booted at least once a day (more like 2 or 3, usually.) Is there special settings in the BIOS I need to set to make it run stable? I have tried changing settings like the 2N command rate and 2.1 volts on the ram and I've tried quite a few combinations of others, to no success. Did I possibly get a bad batch of ram? Thanks for your time!
Sam
Sam
