Hello i have recently built my own computer and am having problems with freezing and blue screening when ihave both of the dual channel gskill F2-6400CL5D-4GBPQ ram sticks in the mobo BIOSTAR TP45E combo. Blue screen error codes read by proffesionals from microsoft tech forums point to memory corruption so i looked into it on biostars end using their update drivers and succesfully updated the standard dual channel controller to what appears in device manager as a storage controller named JMicron JMB368 Controller. Now i ran memtest86+ on each ram stick individually and with them both in just about an hour ago and all 3 tests came back without errors but when running windows for ~15 mins i get a freeze or a blue screen when both ram sticks are in so i am forced to run with a single ram stick to keep the computer functional. other specs include an NVIDIA GeForce GT240, WD 750gig 32mb cache HD, corsair psu 550w, Intel Pentium(R) Processor E6300 dual core 2.8 ghz, and an MSI dvd rw cd drive. need help this is quite frustrating
F2-6400CL5D-4GBPQ dual channel not working
ok the overclock utility that comes with the mobo shows that the memory is only operating at 401.5 mhz the voltage is right in the bios but it only gives me a few options for mhz settings for the ram should i manually change it to 800? or just leave it on auto?
ok i checked the settings and manually adjusted the ones you told me to except for the voltage because i can't find a setting in the bios to change that. i have updated the bios and it is up to date, i took a few pictures of the bios screen on the ram settings area and here they are(sorry couldn't figure out how to post them so i uploaded to my facebook)
http://www.facebook.com/photo.php?pi...&id=1372685978
one of those should work i hope
Ok i double checked the entire menu and could not find anyway to change DRAM voltage i did however find DDR voltage but its max setting available was 1.85 volts. i'm utterly confused here and its pissing me off my most probable solutions on my end are that the dual channel controller doesnt work or the chipset is wackey. i submitted a query to biostar but they havnt told me crap and its been like 5 days
