i have a GB-EP43-UD3L with a e8400 and ram kit f2-8500cl5d-4gbpk
it does run on here. not at normal speeds though.
my CPU is supposed to be a 333 fsb cpu. and the ram at 533=1066.
will at "stock" setting it will not run. mem test will error out.
so what i have come up with over these last few days. is. as fallows.
(on a side note, i really hate typing)
mobo voltages need to be changed.
ram up to 2.1 MCH need to be 1.2-1.3
cmd needs to be 2.
tRD needs to be at least 8. maybe higher. i was able to get mine to 7 but not the 5 i was hoping for.
anyhow. my cpu and mobo will run at 400 FSB for a 1-1 ratio w/ram. but i wanted 1066 ram. and my mobo will not run a 400 cpu and 533 ram. wouldn't even boot.
untill now.
the ram needs to be in slots 2 and 4. as 1 -3 will not work. no matter the timings.
heck you can put them in 1 and 2 it still says duel channel interleave.
there is a "latch" setting you can change in the bios. i have no idea how the a vs b vs c v d setting make that big of a difference when the ram would be at the same speed for different ones. but it does.
now my questions.
is it better to have my ram at 400=800 with a 1-1 ratio with the cpu or at 533-1066 and 3-4 ratio.
should i stay with the 4 gb at 1066 or drop to 800 and have 6 gb ram?
here are some screen shots that might be of some help.
i want performance i run several VM's and premiere and game also.
hum.. it's not letting put images up....
cmd needs to be 2.
untill now.
now my questions.
