I am having trouble getting two different computers to be stable with one of the two sticks I have of F2-8500CL5D-4GBPK. Specifically, I receive bluescreens and hardlocks in Windows 7.
My hardware:
Corsair 750W TX PSU as well as Mushkin 550W
Asus M4A78-e as well as Asus P5Q Pro motherboard
Intel Core 2 Duo E7400 as well as AMD Phenom II 940 processor
G.Skill 4GB F2-8500CL5D-4GBPK
I have tested the memory with Memtest86+, both sticks together and individually for many hours and at least 20 passes and received no errors. I have also run Prime95 blend for 3 hours with no errors.
I have tried updating the BIOS, tried DRAM voltages of 2.0-2.2, and have tried upping the NB voltage, and manually entering timings as suggested in many other threads on this forum for similar or identical hardware. I consulted your BIOS guides extensively.
One stick works fine under any stress I have attempted, but one stick does not.
I beleive I need to RMA the one stick, or both, or whatever is the policy when half the pack is faulty. I submitted an RMA to ncix.com stating the above, but it was declined, even though it seems it is not uncommon for bad RAM to pass various tests but malfunction in actual use.
The fact that I have used two wildly different computers, and receive complete stability with one stick but not the other on both systems, should be enough for to warrant an RMA. Please advise.
C.C.
ps. Link to my current troubleshooting on the retailer's website:
http://forums.ncix.com/forums/?mode=...oduct_id=28306
My hardware:
C.C.
