Hey everyone, I have a question concerning some new RAM I'm hoping to purchase.
Here are the specs for my motherboard -
http://support.gateway.com/s/MOTHERB...6157Rsp2.shtml
Now, I'm trying to decide which RAM will be best for my motherboard and setup. I want to add a total of 4GB to my system either through 4 x 1GB stick or 2 x 2GB sticks. I'm not sure which will provide the best performance. My motherboard has 4 slots, each pair supporting duel channel. Here is what I'm trying to choose from -
TWO OF THESE:
http://www.newegg.ca/Product/Product...82E16820231098
Specs:
Brand: G.SKILL
Model: F2-6400CL5D-2GBNQ
Type: 240-Pin DDR2 SDRAM
Capacity: 2GB (2 x 1GB)
Speed: DDR2 800 (PC2 6400)
Cas Latency: 5
Timing: 5-5-5-15
Voltage: 1.8V - 2.0V
Buffered/Registered: Unbuffered
Multi-channel Kit: Dual Channel Kit
Heat Spreader: Yes
OR
ONE OF THIS:
http://www.newegg.ca/Product/Product...82E16820231122
Specs:
Brand: G.SKILL
Model: F2-6400CL5D-4GBPQ
Capacity: 4GB (2 x 2GB)
Cas Latency: 5
Timing: 5-5-5-15
Voltage: 1.8V - 1.9V
Heat Spreader: Yes
Essentially the same amount of RAM just in two different formats. Let me know what you guys think, thanks!
TWO OF THESE:
Specs:
Brand: G.SKILL
Cas Latency: 5
Timing: 5-5-5-15
Heat Spreader: Yes
OR
ONE OF THIS:
Specs:
Brand: G.SKILL
Cas Latency: 5
Timing: 5-5-5-15
Heat Spreader: Yes
