question before purchuse
  • question before purchuse
    Hi, I want to buy two of these:
    F2-8500CL5D-4GBPI-B (G.Skill DDR2 4096MB 1066MHZ Dual Channel 4GBPI CL5-5-5-15 BLACK EDITION)
    I have an Asus Maximum II Formula
    My processor:Intel Core 2 Duo E8400 3.00 GHz
    Will it support my mainboard?
    Should be no problem....with 8GB though don't trust the ASUS auto setup, enter your base timings, DRAM voltage and Command rate manually, and when you initially install them suggest having CPU at default speed, and install one set at a time rather than all 4 sticks at once.
      Honest opinion. I would skip these sticks for this board they won't reach designed speeds in any state, if someone disagrees prove me wrong.
      Would suggest searching HZ serie sticks, if something but once again just personal opinion.
        Tradesman:
        Ok, But I don't see why. and How should I insert the timing,DRAM voltage and command rate manully?
        what are the exect values.
        thanks reguardless
        Genetix:
        thank you for your advice, but if you had a bad experience with this board and or with these sticks it doesn't necessarily means that the products have a computability issues.
        In fact, it's impossible for a system to display it's full speed as there are a lot of bottlenecks that prevent those speeds, so the 'burden' of proofing is on you.
          Originally posted by Skeith View Post
          Genetix:
          I do not have bad experience I'm using thse memory modules.
          very incorrect in everything in this line. bottleneck is something you get for 1 component bottling up. This does not mean you cannot see another component full speeds what it does mean you would be preventing component speed with another component which in this case is ~twice as fast as the memory and quad bumped.
          I don't need to prove anything you can check my topic on sticky under this same forum and repeat myself, if someone will see anything I said wrong prove it.
            Should have absolutely no issues with that motherboard and memory package.
