Not sure if this is the correct place for this post but move if need be.
here is my issues i have recently done a RMA on my F2-8500CL6D-4GBNQ kit. They went bad on me... not sure why but they did...
well i received the product back and i been using it for about 2 weeks maybe if that and they have gone bad once again causes my computer to blue screen and lock up... i have ran memtest 86+ on them and it doesn't make it past 1% and i start getting red errors on the screen... also my board supports the 1066 but it doesn't auto set to use it at that its only been running at 800 not sure if that can cause it but i tried bumping it up in bios to 1066 and tried to run memtest and it locked up before even getting started...
what do i need to do about getting this fixed obviously i need to RMA them once again... but should i request for a different set as they are suppose to be compatible with my chipset/board
System Specs
Biostar T-Series TP43D2-A7
Intel Core 2 Duo 8200 2.3ghz
4GB G.Skill F2-8500CL6D-4GBNQ
500GB Western Digital
1TB Western Digital
580w PSU
Nvidia 8800GS
32" HDTV/Monitor
Windows 7 x64
System Specs
1TB Western Digital
580w PSU
Nvidia 8800GS
32" HDTV/Monitor
Windows 7 x64
