F2-8500cl5d-4gbpk + m3a32-mvp deluxe wifi
  • F2-8500cl5d-4gbpk + m3a32-mvp deluxe wifi
    I have a Asus M3A32-MVP DELUXE WIFI Motherboard, AMD 9950 CPU, and G.Skill F2-8500CL5D-4GBPK Memory. I recently updated my bios to 1903 and lost all my bios settings. I am not looking to over clock or anything, just looking to to run memory at its full spec. Thank you
    Set base timings manually to 5-5-5-15, Command Rate 2N (or 2T), DRAM voltage to 2.1
      Thank you Tradesman trying now
        if it still can't work, please try to increase NB and HT voltage to 1.4-1.5v to improve the stability while running at DDR2 1066
        thanks
        G.S
