Hey. Looking for 4GB, looking for stability / compatibility with this motherboard. Building a computer for someone over Thanksgiving weekend, and I don't mind digging into the BIOS, but it isn't his thing, and I won't be back to their house until Christmas, and then again Easter, etc you get the idea.
Am impressed by the participation in this forum by GSKILL TECH and others.
I want to play a bit with overclocking, but for now with stock HSF. It isn't the main goal. I don't have to have 1066, but don't want 800 either; I'm thinking 900 or so would be fine, if I could keep it at 4-4-4 timings.
So I'm open to alternatives, but it seems like I'd want the PK, the HK, or the PI-B. Specifically, one of the following (in random order):
F2-6400CL4D-4GBPI-B
http://www.newegg.com/Product/Produc...82E16820231209
F2-7200CL4D-4GBPI-B
http://www.newegg.com/Product/Produc...82E16820231211
F2-6400CL4D-4GBHK
http://www.newegg.com/Product/Produc...82E16820231219
F2-8500CL5D-4GBPK
http://www.newegg.com/Product/Produc...82E16820231166
All are the same price, and all have very solid reviews.
The 6400 and 7200 PI-B look to be the exact same sticks, just listed twice with different volts. Is this true or is there a difference, such as warranty?
The HK doesn't seem to be mentioned much if at all on these forums, which is a negative.
On the PK, I'd lower the MHZ to whatever is needed to get 4-4-4 timings.
I'd like to order one tomorrow at the latest, so that it will arrive in time to build it next weekend.
Thanks.
PS - Oh and off topic, if anyone has a rec on a good DVD drive compatible in Windows 7, I'm listening. The reviews on those things are all over the map.
F2-6400CL4D-4GBPI-B
F2-7200CL4D-4GBPI-B
F2-6400CL4D-4GBHK
F2-8500CL5D-4GBPK
Thanks.
