Gskill F2-8500CL5D Trident and P5KPL SE
  • Gskill F2-8500CL5D Trident and P5KPL SE
    hi
    i buy gskill trident ddr2 1066 1.8 v
    and install in p5kpl se
    my mb chipset is g31 and support 1066 oc
    my cpu is q9550 and in this bus memory just boot in 667 800 1000 1100
    in 1100 system not boot but in 100 boot
    !my mb is 1066 oc
    how i config memory voltage in this mb
    memory voltage start in 1.85 v to 2.264 v
    You'll want your voltage at 1.8
      That a sad piece of board indeed if it wouldn't be blinking would think it's made of wood or something. just joking of course.
      for one your NB is gonna run hot as hell. So, I suggest you check the cooling on that. What goes to voltages 1.85v is 1.93v on this board on latest BIOS so should ok with that. Only way you'll get that to run on 1066Mhz will be to add the Q9550 333Mhz FSB which will drop you open 1067Mhz in 4:3 multiplier that creates stress on NB you might wanna use lowest voltage for NB Volt just for save the board a little.
      (if your board (as the Q9550 should default 333Mhz FSB) for some odd reason would run already on 333Mhz that would need to be raised to 355Mhz ~3.1Ghz so memory 1000Mhz 4:3 can be 1066Mhz. however, I can't really see how this scenario would be possible.)
      -edit-
      all in all considering CPU you are running and the board I would suggest you to run 1:1 clocks specially, if you OC a little. Would be faster in the end.
        i sell my mb
          so you changed it to P5Q SE?
          G.S
