i have problems with my Gigabyte Board and dual channel
Motherboard: GA-EP45-DS4 Rev. 1.0 with Bios F8
RAM: F2-8500CLD5D-4GBPK
CPU: Intel Q9450 2.66Ghz.
If i try to install the two 2gb modules in dual channel system dosnt even start.
If i install them in none dual channel (Bank 1 & 2) my system works but sometimes i get errors resulting in memory dump (blue screen).
Perfomance Enhance Standard
Timings are set to 5-5-5-15 by Bios
Memory Frequenzy @ 1066
Everything else auto
What settings should be used? Thanks in advance for your help.
