I can't get both sticks to work stable ,only 1 stick will work right.I've tested each stick with memtest for 3 hr's no errors.System will boot but fails under load using both sticks" 4GB" in both channels 1,3 or 2,4 doesn't matter.However 1 2GB stick works fine i've been using just 2GB for six months now @ 5-5-5-15 2.1 volts , 533MHz. With both sticks iv'e tried low default settings of 1.8 volts and 2.0 volts didn't help.Thanks for any help or "support" would be great.
Q9400.2.67MHz _GiGABYTE EP45-UD3P_Arctic7cooler_ F2-8500CL5D-4GBPK gskill @1066 2.1V_750W P&C_XFX 1GB HD 4890_640cavBlk_23"acer 1080p_Lian-Li K7B_XP pro sp3
