Model of the motherboard: Gigabyte P35-DS3L rev 2.0 running latest F9 bios
Model of the memory: 4 sticks of 1GB PC8500, exact for each pair is 1GBx2 F2-8500CL5D-2GBPK
Model of the CPU: Intel Core 2 Duo E8400
The problem is that I had been using 2 sticks of the above listed memory on my WinXP system for quite a while with no issues. It was running fine in everything I threw at it, from regular windows use to 3d gaming. I recently upgraded to Windows 7 64-bit and noticed the system was running a bit slow and would run better with 4GB, so I decided to order another pack. (system was running perfectly stable with the original 2gb at 1066mghz 5-5-5-15) I didn't think this would be a problem as my motherboard claims to be able to run 8GB. The problem I've run into is that 3d games will cause a blue screen and reboot the computer or the game will just crash out, sometimes windows will start to error out and windows explorer will begin to crash. For example, this is the error I keep getting when I try to play World of Warcraft:
This application has encountered a critical error:
ERROR #132 (0x85100084) Fatal Exception
Program: Z:\World of Warcraft\WoW.exe
Exception: 0xC0000005 (ACCESS_VIOLATION) at 0023:7117F15A
The instruction at "0x7117F15A" referenced memory at "0x000002B8".
The memory could not be "read".
Press OK to terminate the application.
Other 3d apps will run but crash after some time, like the benchmark 3DMark06 or 3DMark Vantage
I am not overclocking at all, and all settings in bios are at optimum default settings. All votages and mem and cpu settings are at auto values. The ram is receiving 2.08v per the BIOS and windows. The only thing I notice is the original 2 sticks which are in slots 1 and 3 might have different auto SPD settings than the new 2 sticks in slots 2 and 4 (as per CPU-Z). The 2 sets of sticks have different tRC settings of 47 and 48. If these timings are different, I'm wondering if any of the other timings are conflicting, and this may be causing problems when running more intense 3d gaming?
I've run Memtest86+ v4.00 for 3 full iterations (3 hours) at the following timings with no issues, but again, crashing happens randomly in windows and when trying to do 3d gaming:
Performance Enhance = [Standard]
CAS Latency Time 5
Dram RAS# to CAS# Delay 7
Dram RAS# Precharge Delay 7
Precharge Delay (tRAS) 20
ACT to ACT Delay (tRRD) [Auto]
Rank Write to READ Delay [Auto]
Write to Precharge Delay [Auto]
Refresh to ACT Delay [Auto]
Read to Precharge Delay [Auto]
Static tRead Value [Auto]
Static tRead Phase Adjust [Auto]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [+0.300V]
PCI-E OverVoltage Control_ Standard
FSB OverVoltage Control___ [+0.1V]
(G)MCH OverVoltage Control [+0.1V]
CPU Voltage Control_______ Standard
I've been able to get the system completely stable by running the RAM at 800mhz with 4-4-4-12 timings. Obviously, I'd love to get the ram running at it's rated speed.
Are there any exact timings you can suggest for this motherboard or any other settings I could change in the BIOS to make my system stable again while running the 4x1GB sticks at 1066mhz? Thanks.
CAS Latency Time 5
