I found F2-8500CL5D-4GBPK is very unstable to run 1066 Mhz on GA-MA785GPM-UD2H with Windows 7 Ultimate.
Motherboard: GA-MA785GPM-UD2H
CPU: AMD Athlon X2 Dual Core 245
RAM: F2-8500CL5D-4GBPK
I have tried BIOS settings as follows but no luck to get it working well :
CAS Latency - 5T
RAS to CAS R/W Delay - 5T
Row Precharge Time - 5T
Minimum RAS Active Time - 15T
1T/2T Command Timing - 2T
TwTr Command Delay - 4T
Trfc0 for DIMM1 - 127.5ns
Trfc2 for DIMM2 - 127.5ns
Trfc1 for DIMM3 - 127.5ns
Trfc3 for DIMM4 - 127.5ns
Write Recovery Time - 6T
Precharge Time - 3T
Row Cycle Time: 25T
RAS to RAS Delay - 5T
Does anyone know what is correct BIOS configuration for this mother board ?
Many thanks,
CAS Latency - 5T
Precharge Time - 3T
Row Cycle Time: 25T
Many thanks,
