CPU: Phenom II X4 940
MB: TA790GXB A2+
RAM: F2-8500CL5D-4GBPK
This is yet another topic on memory speed.
I cannot get the memory to run at 1066MHz. I raised the voltage to 2.05, set the Speed manually to 1066, and even change some of the timing settings, however, in each scenario i tried the memory won't run at more than 533MHz and/or give BSOD's. It's perfectly stable at 400MHz by SPD, but i bougth 1066 memory and i want it running at that speed.
I would appreciate some sort of confirmation of testing succesfully that combination of hardware, and of course if smeone knows the combination of options to enable/change in the bios, please do let me know.
Thanks in advance.
MB: TA790GXB A2+
Thanks in advance.
