In order to troubleshoot a breaking-down old build I've got myself a nice new system:
Motherboard: Gigabyte GA-EP45C-UD3R
CPU: Intel Dual Core E8500
Memory: G.Skill F2-8500CL5D (2x2GB)
GPU: EVGA GeForce 9800GTX+ (256MB)
The HDDs, Optical Drives, and PSU are a mixed bunch of hardware between 1-3 years old.
This MAY be important: I didn't upgrade the PSU - it is a 3 year old cooler master 450W PSU. Here is a picture of the side panel: http://img222.imageshack.us/img222/3236/1717100103.jpg
First things first - I put in the RAM (slots 1 and 3) and booted up the system without even looking at the BIOS, and it Blue Screened while I was installing Windows. A second try at installing got me into the OS but I got another BSOD while adjusting desktop resolution moments after I had booted up.
I popped in my Memtest 86 boot disk, and rebooted. At the first test (a couple seconds after the machine starts) the computer hard reboots. This happens in slots 1-3 and 2-4 - at exactly the same time in both slots. It happens if the ram is clocked at 1066 and 800. It happens with stock settings or tweaked settings.
I took one stick out and boom, no problems. I swapped sticks into slot 1, and the other one also tested without problems. (I am writing this on a computer with only 2 gigs of memory )
At this point I did some research and came across this forum. I read the messages carefully and worked with the suggestions in this thread: http://gskill.us/forum/showthread.php?t=1169 - I followed the recommendations and there was no change. The settings made no difference.
I know the memory is good, but I'm concerned. Occaisonally the system POSTS without giving me a RAM count, and once or twice when I had an internal card reader connected the computer hung as it POSTED with only "Me" of "Memory allocated ..." or whatever it says before it counts the RAM on the screen. After about five second hung with the "Me " on the screen, it would reboot and do it again. I disconnected the card reader and that hasn't happened again, but I'm obviously nervous. Yesterday, for the first time I got an "IRQL_LESS_THAN_OR_EQUAL" BSOD while using windows with the once stick.
I realize this is probably the motherboard and that will be the end of it. That said, I am concerned about the PSU - I think it has been making intermittent clicking noises. Could the PSU be the cause of all this? My gut tells me no, but I don't know.
I'm ready to try anything. I'm going to borrow a couple sticks of known working DDR2 800 ram later today and try to run them dual channel to see what happens. I'm just completely stumped and am dying for a stable system I can count on.
