I have tried various setting combinations suggested here on my two sticks, although I can get the sticks to run at the proper speed (533) I cannot get them stable. If I put the sticks to 533 with any combination of settings I have tried ends up crashing applications when the sticks are under load.
Right now I'm running the sticks on what the default is on with my motherboard (400mhz) and everything is stable.
My motherboard has the latest bios.
I can take pictures of my bios settings if that will help.
System Info:
AMD Phenom 9950 BE
ECS IC780M-A
F2-8500CL5D-4GBPK
EVGA GeForce 9800 GTX+
System Info:
AMD Phenom 9950 BE
ECS IC780M-A
F2-8500CL5D-4GBPK
