So firstly to name my component so you'll have a feel of what im working with:
Intel Core 2 3.0ghz E8400
Gigabyte EP45-UD3R
G.Skills PC8500 1066 mhz 2x2gb ram
EVGA 9800GT
so i had problems from the very beginning starting from installing XP but i got around it and now im stuck with this problem. I keep having constant BSODs if i have the 2 sticks of ram in slots 1 and slots 2, or slots1 and slots 3 ( but it will only post if i have it at 800 and not 1066). i tried to run everything at 800 but i still got BSODs when i ran a game (left 4dead) system will just freeze and crash and i will have to manually restart.
BUT i just tried manually setting everything to 5-5-5-15 again and dram volts to 2.1 and running it at 1066 and i insert it into slots 2&4 and BAM it works perfectly. but if i were to put it back into slots 1&3... no post and keeps rebooting/restarting.
SO QUESTION:
Does this have to do with the motherboard? or the ram? i ran memtest86+ while having one in slots 1 and TONS of error showed up. Ran it in Slot #2 no errors. Tried it with both sticks and Slot #1 gives me errors every single time. But when i ran it at 800 i didn't get a single error in the same slot #1. So i don't get whats the problem.... help??
currently: running memtest86 overnight at 1066 speeds in dual channel mode in slots #2 and #4. will reply back asap.
Gigabyte EP45-UD3R
EVGA 9800GT
SO QUESTION:
