I have tried to run G.SKILL F2-8500CL5D-4GBPK with 1066MHz (are in the compatibility list for that mainboard) but I was not able to get Prime95 and Memtest86+ to run without errors. I used also the autoconfig (EPP + EPP Voltage).
I got from a friend temporary some Corsair Dominator TWIN2X4096-8500C5D (run with 2.1V) and they work fine with 1066MHz (no errors Prime95 and Memtest86+ 24 hours).
G.SKILL F2-8500CL5D-4GBPK run only fine (with Prime95 and Memtest86+) when run with 800MHz (tested for 24 hours). I was also able to get them down to 4-4-4-12 (stable) with 800MHz.
CPU: AMD X3 720 BE
Mainboard: Gigabyte GA-MA770-UD3 V2.0
Do you have suggested settings for my mainboard to run them with 1066MHz, please?
CPU: AMD X3 720 BE
