Hi All,
I have recently upgraded the RAM and CPU in My ASUS M2N32-SLI Deluxe MoBo (BIOS version 2208 latest from ASUS).
I slotted a AMD AM2 Phenon II 940 BE with no problems. However after installing the new G.Skill DDR2 4G(2x2G)PC6400 800Mhz(F2-6400CL5D-4GBNT) RAM that i purchased, the system wouldn't post from pressing the power button. The board gets power fans turn on, lights etc, but the USB external keyboard, mouse and video display get nothing... Press the reset button while it is in this state however and it will restart and POST fine then load into windows...
This problem seems to happen randomly.
I have loaded the BIOS defaults, changed out the RAM to check faults etc, cant see a problem. It POSTs consistently with my old Corsair memory (DDR667) modules, this problem has only occurred since installing the G.Skill memory. I haven't run MemTest as of yet, but i did run PCMark06 in Windows 7 and did some stress tests and the system seemed stable.
I have tired disconnecting other components, to make sure that the new RAM/CPU wasn't drawing too much power in a spike when its turned on... didn't seem to make a difference
My System specs
AMD Phenon II X4 940 (3.0GHZ) Black Edition CPU
M2N32-Sli Deluxe WiFi Ed MoBo
4 Gig G.skill DD2 800mhz Ram (setup in Dual Channel slots)
MSI 8800GT 1G DDR3 Graphics Card
2x 250Gig WD 16mb chace RAID 0 configuration (Striped)
1 TB Samsung Drive for Storage
Windows 7 OS
ThemalTake Tusumi Dream (430watt power supply)
Please let me know if you need any more information...
Any suggestions would be much appreciated.
cheers,
Aaron
My System specs
Windows 7 OS
cheers,
Aaron
