ASUS M4A78 PRO - F2-8500CL5D-4GBPQ - Settings
  • ASUS M4A78 PRO - F2-8500CL5D-4GBPQ - Settings
    i would like to know if you could tell me how to adjust the settings for a F2-8500CL5D-4GBPQ RAM to work at 1066mhz with a board ASUS M4A78 PRO and a Phenom II X4 940 processor.
    Already tried different settings and i can't get it to work without BSOD and sometimes doesn't even work.
    Sorry for my bad english.
    AI Overclock Tuner: Manual
    DRAM Frequency - 1067Mhz
    DRAM Voltage - 2.1V
    HT Voltage - 1.4V
    DRAM Controller Configuration (submenu)
    DCT Unganged Mode - Enabled
    Power Down Enable - Disabled
    DRAM Timing / Driving Config. (submenu)
    tCL - 5
    tRCD - 5
    tRP - 5
    tRAS - 15
    Rest can be AUTO
    Save and exit and you computer should be running smoothly.
      Hi, thanks for the quick answer.
      I've tried the settings above but PC doesn't even start.
        What slots do you have them installed in? They should be in the two yellow slots. Try the two black ones as well to see if results differ.
          Thanks very, very much.
          Problem solved.
          I had 1 in the yellow slot and another in the black slot.
          Putting both in yellow slot solved immediately the problem.
          Once again thanks.
            Please share your G.Skill Support experience and rate it via the poll system. This will help us improve our Customer Service. Thank you!
            http://www.gskill.us/forum/showthread.php?t=1093
              rate already done.
              As you have noticed my english isn't that good, but I will try.
              Thanks once again.
