Hello:
I recently bought G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) from newegg. I am having some problems with it.
Originally, I had Corsair 2048MB [1024MB X2] DDR2-800 PC6400. When I received the Gskill RAM, I installed it in addition to my 2 GB I had. When I turned the PC on, I wasn't getting any display on my monitor. So, I took the Corsair 2GB out, and tried it with just the Gskill. It worked, but the PC shut down after a while. Later I tried to install the corsair and gskill again to have 6 GB total, and it worked but my PC kept freezing. So I took out my old RAM out, and left Gskill in. It worked all day with just the Gskill. But this morning when I turned my PC on, it would show no display again. So I took the Gskill out completely and left my old one in, and which works fine.
So I'm wondering what the problem is. When my PC was freezing with all 4 RAM slots used, I got a blue screen error saying something about BIOS, but I didn't get a chance to fully read because it restarted quickly. Am I supposed to configure settings? Is it possible for me to use my old RAM in addition to the Gskill so I can have 6GB instead of 4GB?
My PC Specs:
Operating System: Windows Vista 64 Bit
Processor: Intel Core 2 Quad CPU Q6600 2.4 GHZ
Video Card: Nvidia Geforce 8800 GTS 640 MB
Power Supply: Sunbeam 680 Watts
Motherboard: Asus P5N-E SLI nForce? 650i SLI Chipset w/6-channel CODEC, Gb LAN, S-ATA Raid, USB 2.0, IEEE-1394 Dual PCI-E MB
Thank you for your help.
My PC Specs:
