I brought F2-8500CL6D-4GBNQ and GA-EP45-UD3L for my new build. My CPU is a Q8200. I put in only 1 stick of memory on slot 4 for the initial testing. When I turn on the power the first time, all I got is a continuous short beeping. After around 15 times of short beeping, the machine reboot itself and the same beeping happened again. The only thing I can do is swithing off the power supply. There's no POST message display on screen and there's no signal detected by my monitor. I finally reseat my memory from slot 4 to slot 2 and the whole thing work without any issue. The machine boot up and I can installed WinXP Pro and everything seems quite stable so far. I can play game, e.g. Need for speed undercover, for couple hours without crashing. However, whenever I tried to put in my 2nd stick in slot 3 or slot 4, same problem happened, the continuous short beeping and reboot. My motherboard came with bios version F2 and I updated to the latest one F5C. The situation changed a little bit. I can see the first screen displayed on my monitor but then the system reboot and first screen displayed and reboot again. This time no more beeping. I'm not sure if anyone have the same problem or not. Will that be a compatibility issue between the memory and the motherboard? I did contact Gigabyte support to see if this is a faulty motherboard but their respond is quite slow so far. Both stick of memory seems to work if being used alone on slot 2. The reason I'm not using slot 1 is because my tower Heatsink is to close to slot 1. I didn't try other memory as yet because I don't have access to one but will try to do it this coming weekend. Any comment is welcome.
EDIT
The only bios setting I've changed is the DRAM voltage. I changed it from auto to 2.0V.
EDIT
