Compaq NC6400
  • Compaq NC6400
    I want to upgrade a Compaq Notebook Compaq NC6400. I need help finding the right memory since it does not show up in the Ram Configurator.
    I believe the memory installed is 1 GB DDR2 SO-DIMM DDR2 533 (PC2 4200) in the second slot plus the 512 MB originally installed in the machine.
    I'm looking to replace the memory installed for 2 dimms of 2 GB each to reach the maximum capacity the MB allows.
    Your help is greatly appreciated.
    Daniel
    Will drop a note for GSkill Tech to take a look....sorry, but I don't really do laptops. Hopefully he'll be in Fri, if not they should all be back Mon
      Thanks Tradesman, helpful and quick as always, I'll come back on Fri or Mon for answers.
      Have a nice Thanksgiving holiday.
      Daniel
        You too, will be keeping an eye on this
          Would this work? F2-5300CL5D-4GBSA
          $ 45 at NewEgg
            Yes, that memory kit should be the best your laptop can support.
              Thanks a lot, I will order it here: http://www.newegg.com/Product/Produc...82E16820231135
