Upgrade for system with 2x2GB F2-8800CL5-2GBPI
  • Upgrade for system with 2x2GB F2-8800CL5-2GBPI
    I have a Gigabyte X38-DQ6 with a slightly overclocked Q6600@3000 (G0) and with 2x2GB PC8800 PI (the original ones, 8 layer PCB) running at 1000Mhz@1.8V with relaxed timings.
    I'd like to upgrade to another 2x2GB to have 8GB total, but I can't find anymore the same memory sticks. I have a list of some other similar ones available in my country and the price for each. What I'm looking for is STABILITY even if I have to lose performance, and preferally at low voltage (1.8 or 1.9)... my days of hard overclocking are gone
    F2-8500CL5D-4GBPK 2.0-2.1v -> 65?
    F2-6400CL4D-4GBPK 2.0-2.1v -> 60?
    F2-8500 CL5 4GB-Kit Pi-Serie Black 2.1v -> 87?
    F2-6400 CL4 4GB-Kit Pi-Serie Black 1.8-1.9v -> 83?
    What do you guys think? Maybe the best option are the 6400 PI black, but the price difference with the normal 6400 is huge, and probably they can do 1000@1.9v with 5-7-7-19 or so.
    To match, 8500 CL5 will be best. You can try 6400 CL4 too, it should have good results.
      But the PI series, or the other ones?
      BTW, thanks for the quick reply!
        If you want to mix with your original memory, it is best to try PI.
