Hello, is there any chance to run this kit on the Gene mobo?
I know the kit is listed only for the apex - but i would like to choose this kit because it cost not very much more than the 4.600 CL18 Kit (which is listed for the Gene).
Or is this a technical limitation that the gene would not work? Is the voltage 1,5v a problem?
My second thought is:
maybe the 4800 kit is of higher quality and so it work higher speed or lower with lower latency...
(i know it cpu and mobo limited too).
Thanks for helping here!
