I have 16 gigs of G-Skill Trident X F3-2400C10D-16GTX in my Asus Sabertooth Z77 board with xmp enabled, it is teamed up with a I5 3570k processor oc to 4.5.My question is when tightening the secondary settings is it best to raise the initial dram volts a little or is the vccsa volts the one to tweak to make the settings stable.
Voltages for OC Question
Try DDR3-2400 10-11-12-(21/28), 10-10-12-(21/28), 10-11-11-(21/28) and 10-10-11-(21/28). Usually 1.65V are more than enough for this. The secondaries need only very minimal Vdimm adjustments, but adding a little bit of voltage can't hurt either (e.g. up to 1.68V).
You will regardless of voltage probably not be able to hit DDR3-2600 24/7 stable.
See http://www.ocaholic.ch/modules/smart...mid=795&page=3Team HardwareLUXX | Show off your G.SKILL products!
