I have a HP Envy h8-1520t desktop with a Pegatron Motherboard IPMMB-FM Formosa socket Z75 LGA1155 running an i7 3770 3.4Ghz. I just purchased G.Skill RipJaws PC3-12800 DDR3-1600 CL9 16G kit (8gx2) intel XMP ready. I installed them and the are running at 1333mhz instead of 1600mHz, Ive searched the Bois for a place to configure memory or somewhere to enable XMP and have had no success. Am I missing something or just out of luck, The only information I can retreive on the Motherboard is on the HP website and they give no info about overclocking or changing memory timings. Any input would be greatly appreciated.
Unable to enable XMP in Bios
There should be a clear CMOS jumper on the mobo (should be in the manual), could try that, also check to see if there is a newer BIOS...This is often a problem with off the shelf systems as they often have a locked BIOS that doesn't allow many changes...Would also contact them direct as their specs on the system readily state it will run 1600 sticks.
