F4-3200C16D-32GVK on GB Aorus X570 Elite board - RAM not able to run at stated speed
  • F4-3200C16D-32GVK on GB Aorus X570 Elite board - RAM not able to run at stated speed
    SOLVED - Edited Jan 9 2020- Summary – this issue has been solved – why I am not sure.
    {EDIT -Jun 3, 2021
    Have recently upgraded Linux Mint to 20 from 18 and kernel upgrades as well as MB BIOS upgrade. RAM speed returned to native speed. Found I had not documented my original RAM speed tuning procedure. Include that here now.
    Also found detailed informative video - https://video.search.yahoo.com/yhs/s...c8&action=view
    OK now my tuning procedure -
    1) starting in BIOS - Enabling XMP
    2) Iteratively increasing memory frequency, re boot, check if new memory frequency accepted, try next memory frequency level, if boot fails, increase DRAM voltage by 0.01V, reboot, check BIOS, continue increasing voltage until new memory frequency is accepted, repeat step increase in memory frequency.
    3) System didn't get to rated RAM memory overclock speed but one step below.
    3a) To check that your setting is stable; complete boot up got to terminal - type "sudo dmidecode -type 17" RAM speed will show up.
    4) Strongly suggest not to exceed DRAM voltage of 1.40 V unless you know for sure what you're doing. Watch video link above - don't be intimidated by technical detail in video by glean info from it. (Note he exceeds 1.4V)
    End of Jun 3, 20212 Edit}
    Jun 3, 21 inxi -Fxz
    [HTMLsteve@steveX570:~$ inxi -Fxz
    System:
    Kernel: 5.4.0-73-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
    Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
    base: Ubuntu 20.04 focal
    Machine:
    Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <filter>
    Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <filter>
    UEFI: American Megatrends v: F32 date: 01/18/2021
    CPU:
    Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen
    L2 cache: 4096 KiB
    flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
    bogomips: 114984
    Speed: 2194 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 2196 2: 2195
    3: 2189 4: 2192 5: 2195 6: 2191 7: 2196 8: 2189 9: 2196 10: 2196 11: 2194
    12: 2194 13: 2196 14: 2196 15: 2192 16: 2188
    Graphics:
    Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 0a:00.0
    Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati
    unloaded: fbdev,modesetting,radeon,vesa
    resolution: 1920x1200~60Hz, 1680x1050~60Hz
    OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.35.0
    5.4.0-73-generic LLVM 11.0.0)
    v: 4.6 Mesa 20.2.6 direct render: Yes
    Audio:
    Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
    bus ID: 0a:00.1
    Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus ID: 0c:00.4
    Sound Server: ALSA v: k5.4.0-73-generic
    Network:
    Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
    v: 5.6.0-k port: f000 bus ID: 04:00.0
    IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Drives:
    Local Storage: total: 2.05 TiB used: 258.35 GiB (12.3%)
    ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP600 size: 931.51 GiB
    ID-2: /dev/sda vendor: Western Digital model: WD360ADFD-00NLR5
    ID-3: /dev/sdb vendor: Western Digital model: WD1500AHFD-00RAR5
    ID-4: /dev/sdc vendor: Samsung model: HD103UJ size: 931.51 GiB
    ID-5: /dev/sdd type: USB model: OLYMPUS PEN-F size: 59.48 GiB
    Partition:
    ID-1: / size: 83.84 GiB used: 9.29 GiB (11.1%) fs: ext4
    dev: /dev/nvme0n1p2
    ID-2: /home size: 173.17 GiB used: 3.51 GiB (2.0%) fs: ext4
    dev: /dev/nvme0n1p3
    ID-3: swap-1 size: 14.16 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
    Sensors:
    System Temperatures: cpu: 43.0 C mobo: 16.8 C gpu: amdgpu temp: 34 C
    Fan Speeds (RPM): N/A gpu: amdgpu fan: 844
    Info:
    Processes: 354 Uptime: 1h 18m Memory: 31.37 GiB used: 2.08 GiB (6.6%)
    Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17
    inxi: 3.0.38][/HTML]
    Jun 3, 21 BIOS screenshot attached
    I found this Corsair article informative - https://www.corsair.com/corsairmedia...ckingGuide.pdf
    At one point I had both sticks of RAM (2 x 16GB) installed and it booted to RAM speed of 3208MHz @1.38V. When I went back into BIOS to try to save that profile and restart, I could not get that speed again, RAM reverted to native speed 2133MHz.
    Inadvertently I tried reducing the System Memory Multiplier one step from Auto (32?) to 31.33.
    Rebooted and the system came up to 3133 MHZ. I have repeated this several times after trying to tweak other setting seeing if I could get to 3200.
    I’m happy with 3133 MHz for the time being.
    I don’t understand the relationship that the Corsair guide talks about between latency and the other mentioned RAM variables. Keep that for another time. Hope this helps. End Summary.
    Hello - I've been doing this 11 year upgrade to CPU, Motherboard, RAM, GPU and Flash drive - see system inxi post.
    Before finding your forum, I've gone through many setting trials with both sticks installed from Auto with BIOS XMP enabled Profile 1 to manually setting variables.
    The RAM speed result with 2 x 16GB sticks in slots A2-B2 was always native 2133 MHz. Read a posting on your forum and tried individual sticks in all slots. All except slot B2 came up with 2133MHz while slot B2 came up with 3200 MHz for both sticks.
    I don't know if my conclusion of something wrong with channel A on the motherboard is correct or not. It seems that both sticks can perform individually at 3200 MHz.
    Any comments would be appreciated
    Thanks.
    Edit - note inxi post is done with only 1 stick in slot B2.
    Edit 2 - posted BIOS screenshots one inserted two attached
    [HTML]steve@X570:~$ inxi -Fxzd
    System: Host: X570 Kernel: 4.15.0-72-generic x86_64 bits: 64 gcc: 7.4.0
    Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu4)
    Distro: Linux Mint 19 Tara
    Machine: Device: desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: N/A
    Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: N/A
    UEFI: American Megatrends v: F11 date: 12/06/2019
    CPU: 8 core AMD Ryzen 7 3700X (-MT-MCP-)
    arch: Zen rev.0 cache: 4096 KB
    flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 57491
    clock speeds: max: 3600 MHz 1: 2190 MHz 2: 2201 MHz 3: 2195 MHz
    4: 2195 MHz 5: 2190 MHz 6: 2195 MHz 7: 2192 MHz 8: 2192 MHz
    9: 2195 MHz 10: 2195 MHz 11: 2193 MHz 12: 2192 MHz 13: 2194 MHz
    14: 2191 MHz 15: 2194 MHz 16: 2183 MHz
    Graphics: Card: Advanced Micro Devices [AMD/ATI] Device 731f bus-ID: 0a:00.0
    Display Server: x11 (X.Org 1.19.6 )
    drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
    Resolution: 1920x1200@59.95hz, 1680x1050@59.88hz
    OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10, DRM 3.33.0, 4.15.0-72-generic, LLVM 9.0.0)
    version: 4.5 Mesa 19.2.0-devel Direct Render: Yes
    Audio: Card-1 Advanced Micro Devices [AMD] Device 1487
    driver: snd_hda_intel bus-ID: 0c:00.4
    Card-2 Advanced Micro Devices [AMD/ATI] Device ab38
    driver: snd_hda_intel bus-ID: 0a:00.1
    Card-3 Logitech Webcam C310 driver: USB Audio usb-ID: 001-005
    Sound: Advanced Linux Sound Architecture v: k4.15.0-72-generic
    Network: Card: Intel I211 Gigabit Network Connection
    driver: igb v: 5.4.0-k port: f000 bus-ID: 04:00.0
    Drives: HDD Total Size: 2037.4GB (13.9% used)
    ID-1: /dev/nvme0n1 model: Force_MP600 size: 1000.2GB
    ID-2: /dev/sda model: WDC_WD360ADFD size: 37.0GB
    ID-3: /dev/sdb model: SAMSUNG_HD103UJ size: 1000.2GB
    Optical-1: /dev/sr0 model: N/A
    rev: N/A dev-links: cdrom,cdrw,dvd,dvdrw
    Features: speed: 48x multisession: yes
    audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: N/A
    Partition: ID-1: / size: 84G used: 9.2G (12%) fs: ext4 dev: /dev/nvme0n1p2
    ID-2: /home size: 174G used: 2.7G (2%)
    fs: ext4 dev: /dev/nvme0n1p3
    ID-3: swap-1 size: 15.20GB used: 0.00GB (0%)
    RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
    Sensors: System Temperatures: cpu: 16.8C mobo: 16.8C
    Fan Speeds (in rpm): cpu: N/A
    Info: Processes: 320 Uptime: 8 min Memory: 1149.8/16051.3MB
    Init: systemd runlevel: 5 Gcc sys: 7.4.0
    Client: Shell (bash 4.4.201) inxi: 2.3.56[/HTML]
    What a coincidence, I have a problem OC'ing this product too and we posted at the same time !
    I hope you'll find an answer to this and that it could be useful for me !
      So A2 slot only works at DDR4-2133?
      Have you tried A1 to see if it can boot?
      Check CPU socket pins and cooler installation to make sure they are good. In some cases re-seating the processor can help. If problem persists, trying another motherboard may be necessary.
        Hello & thanks for replying. Using sticks one at a time and alternating in all slots ie 1 x16 GB in A1,A2,B1,B2. All positions boot up but fine but in positions A1, A2, B1 RAM speed is native 2133MHz and only in B2 is RAM speed 3200 as shown in BIOS photos.
