If you would like to be able to access numerous controls of your system at once, Try GodMode, been playing with it for a bit and it comes in handy. To set it up, simply create a new folder on your desktop and rename it to:
God Mode.{ED7BA470-8E54-465E-825C-99712043E01C}
which will change it to an ICON similar to Control Panel and be titled GodMode
double click and it provides you with a menu to access all kinds of system controls
PS - if you want to personalize, simple change GodMode in the above string to whatever you like, i.e. Git Ur Done, if a fan of the cable guy
