Hi there,
I have recentrly bought ASUS p9X79 DELUXE and 4 x 4gb DIMM (g.skill F3-17000CL9Q-16GBZH) 2133 Mhz.
Ram are in the updated QVL and I have flashed to latest bios version.
My issue is that are recognized only 8GB RAM and in BIOS settings I found that two dimms are in "abnormal" state.
I have checked manual and I can confirm RAM are mounted as suggested.
XMP Profile enable, all bios settings are in auto.
I have tryed a lot of combination on BIOS gui:
XMP profile #1 enable
XMP profile #2 enable
VCCSA 1.15v
VCCSA 1.2v
DRAM voltage 1.65v
I get in some shot the correct bus bandwidth, 2133 MHZ, but always only 8GB ram. The modules installed on slot DIMM_D1 and DIMM_C1 are always showed as abnormal.
Operating System recognize only 8GB too, even if I run CPU-z tool (latest version) and it shows I have a total of 16GB..
Can anyone help me plz?
VCCSA 1.15v
VCCSA 1.2v
DRAM voltage 1.65v
