F3-12800CL9T2-24GBRL Gigabyte GA-X58A-UD3R
Intel Core i7 CPU 930 @ 2.80 GHZ
I'm currently running 24 gigs at 1033 mhz(default) everything seems fine.
I'm trying to set it up for 1600 mhz.
I have been running 6 gigs of OCZ3G1600LV6GK @ 1600 mhz with no issues.
I tried the same settings I used with my OCZ memory and I get a warning and it reset to a default setting.
Set Performance Enhance to {Standard}
Set DRAM Timing Selectable to {Expert}
Set Memory Timings to CL 9-9-9-24 (CL-TRCD-TRP-TRAS)
Set Command Rate to {2}
Set QPI / VTT Voltage to {1.35 Volts}
Set DRAM Voltage to {1.65 volts}
System Memory Multiplier (SPD) 12.0
Uncore Clock Ratio x25
tRFC 88
OCZ3G1600LV6GK
tRFC 88
OCZ3G1600LV6GK
