Thank you. First of all, thank you for the work you do. There are so many boards of naysayers who say, 'get the cheapest memory. It does not matter what speed or CAS. You won't be able to tell the difference.' You speak with authority and knowledge.
I am buying an ASUS Z87 Sabertooth in conjunction with an Intel Haswell i7 4770k. I will be making a clean install of Windows 7 Pro on an SSD.
I do CAD work, map designing using ARC-GIS -like programs, Video editing, raw photo editing, Photoshop the entire Adobe Suite.
I am considering two memory configurations and want to know which is better - both are 32 GB -
Ripjaws X - F3-1866C9Q-32GXM(XMP) (9-10-9-28, CAS 9) 1.5 V.
Ripjaws Z - F3-14900CL10Q-32GBZL(XMP) (10-11-10-30 CAS 10) 1.5V
I am leaning towards the Z's as I read on the board that the "Z's" were designed as 4 channel and felt that was somehow a plus. But the "X's" have slightly faster timings. Is it enough to make a difference?
I was told by an Asus chat person that using anything faster than 1866 would void the warranty. But that brings up another question - how much faster would I havce to go to see a difference from 1866? Or is there even a noticeable difference from 1600 to 1866? Would I have a more stable system if I stuck with 1600?
