I'll try to be brief. I came across this excellent forum because I was going bananas trying to get the Gigabyte H55M-S2V [ver 1.3] mobo to accept the Gigabtye touted "16 GB max memory" which their own user's manual [issued August 6, 2010, Rev. 1301] cited the mobo as being able to support 16GB DDR3 memory using two 2 X 8 DDR3 sticks . I tried everything but Windows 7 [64 bit] refused to budge and load itself with 16 GB installed into the mobo and so I hit the internet for answers.
I came across this forum and a quite excellent discussion between "Tradesman" and I believe another member of the forum called "Stephen H" who had the identical problem I had with this mobo and trying to install two 2 X 8 sticks sticks but no matter what one tried, Windows would not load with 16 GB of system memory [two 2 X 8 sticks].
Tradesman gave excellent possible solutions to the problem and, I must say, went the extra mile in that discussion looking for answers and I have an old Army buddy down South who loves to, as he says, "tinker' with these machines who saw Tradesman's suggestions and said they were "... the best I"ve seen to coax out Windows to load when it has system memory loading issues ... " and my buddy 'also' commented that if those solutions didn't work, and I quote, "... there is a very real possibility that this mobo just may NOT support 16GB but most likely only HALF that amount at 8 GB memory." To make a long story short and to note for the record that this mobo is still touted at bargain basement sales here and there on the internet that it can allegedly support 16GB but IT CAN NOT support 16GB and Gigabyte itself has REVISED their archives [take a look!] and any mention of "16 GB system max" is now nowhere to be seen [** despite their own 2010 user's manual stating otherwise!] and the ==revised== system memory max for the H55 [through version 1.4] mobo 'finally' reads "8 GB system max memory" in those two H55 DIMM slots! In effect, those going on what the mobo was touted to do [16GB] wasted their time [like yours truly here!] trying to, indeed, "cajole" Windows 7 to load when the H55M-S2V mobo IN FACT can NOT support 16GB! Only 8 GB max. As Gigabyte 'now', 3 years after the fact, finally admits on their website archive for the H55M-S2V mobo. --- DocTony
a couple people here asked if I could help with a couple other brands of DRAM and some other components and while I don't mind helping anyone with most anything here, I'm not GSkill and don't really feel right about doing other DRAM here and that's basically what I told them, they then asked if I could check in over there, so got there names there and signed up - and those forums amaze me....there are so many passing bad info just on DRAM alone, when I hop in, it's enough to drive you crazy....but I sort of enjoy it, can be a bit more opinionated on things.
