Building a new PC need some advice on RAM
  • Building a new PC need some advice on RAM
    Greetings!
    I went ahead and built http://pcpartpicker.com/p/V1ko
    MB: Biostar B75MU3+ Micro ATX LGA1155 Motherboard
    Processor: Intel Core i5-3330 3.0GHz Quad-Core Processor
    This build suggested Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1600 Memory but this has been discontinued. I've used G.Skill memory for some of my other builds and I remember this forum being extremely helpful so I decided to see if anything was suitable for the setup. I will be using this for gaming mostly etc so any performance enhancing suggestions are welcome!
    Thank you!
    For 8GB, with your mobo/CPU combo think I'd suggest the 1600 Snipers F3-12800CL9D-8GBSR or the Ripjaws X F3-12800CL9D-8GBXL
      Appreciate the prompt response I decided to get the Ripjaws X F3-12800CL9D-8GBXL
        Think you'll be pleased w/ them, let us know how it goes!
