I received my G.Skill Trident X series DDR3-1866 PC3-14900 16GB (2x8GB) RAM (F3-1866C8D-16GTX) from Newegg.com today.
This particular ram is advertised as having a removable top heat fin. The manufacturer's directions for removing this are as follows:
1) Unscrew retaining screws at both ends of the heatsink
2) Remove red fiber washers
3) Slide heat fin off.
Simple enough. However, when I tried to slide the heat fin off, NOTHING HAPPENED. It wouldn't budge at all. I contacted GSkill's USA tech support (1-9095986860) and they told me after removing both screws, the heat fin should slide right off. I kept at it, carefully manipulating the memory kit for the better part of an hour. My hands were cut by the sharp edges of the fin.
In despair, I tried hammering the heat fin to remove it. One popped right off...good enough. The last one completely blew up. The heat sink itself (the black wrap around part) slid off, taking off two of the RAM modules. The "removable" heat fin is STILL stuck to the other half of the heat sink. It STILL will not slide off.
I destroyed my RAM, but that was as the direct, proximal consequence of GSkill's manufacturing process. The heat fin should slide off without any force. The fact that it still won't slide off even after the application of force points to a manufacturing error.
Now, the question is what are my options?
GSkill phone tech support is pretty unhelpful.
Advice would be appreciated, thanks!
http://i.imgur.com/bJp0Q.jpg - on the left is the "successfully" removed heat fin. On the right is the destroyed one. Notice the heat fin still hanging on for dear life. You can see the stripped RAM modules.
