I almost bought GSkill Sniper Series Turbulence II 24 GB memory pack. I would like to know what is this diffidence from Sniper series to + Turbulence II
Thanks for your time
and yep when the time comes you'll prob go with a different mobo/socket, they are ever evolving, DDR4 is just around the corner...the good thing, gaming wise, is that the GPU are progressing even faster, so if you decide things are getting 'slow', there will be newer GPUs that will give you a huge jump gaming wise.
