Hello all,
Looking into getting a new power supply.. I would like it to be full modular and around 850. I have chosen 2 separate power supplies here:
http://secure.newegg.com/WishList/Pu...umber=27641448
However, it shows that the HX is a tier 2 on the eggpert list and the AX is a tier 1. However, the HX has more 8 pin connectors then the AX, has a .8amp on the -12 rail vs a .5am on the AX, etc..
I just want the best power supply I can get. I know this is controversial, so lets not start a war
What I need to know? Which one is better? If you suggest something even better let me know.
Current Hardware information located HERE
Kind regards,
Saxamo
http://www.saxamo.com/downloads/monitor/IMG_0647.jpg
Kind regards,
Saxamo
