Got a technical problem?
Thank you!
See more
See less
Question for Gskill KM570 users
  • Question for Gskill KM570 users
    I am thinking of buying this keyboard but I don`t like it becasue it has macro button right next to volume controls. I often use volume controls and if I would press accidentally that, then keyboard would enter macro mode and only solution to back to normal mode is to press macro button again. Is there a way to disable that key? Non RGB version doesn`t have software and as I read on youtube comments people are complain that macro recording has some time delay between keys. So without software it is not possible to deactivate macro?
    RGB version has software so I want to know is it possible to deactive macro button so that if I press it that nothing happens?
    bump
      Unfortunately, at this time the MR key can not be disabled, only removing the key itself if it is a serious problem.
