Wighdash manager very high cpu usage
  • Wighdash manager very high cpu usage
    Since the last versions(current: 1.2.9519.34181), wigidash manager is using between 5-6% cpu usage. It was not that way before with Aida64.
    Any suggestions?
    Thank you!
    Try disabling the features in settings, that you don't use/need. Some of them will reduce the CPU load.
    If it does not help, try v1.2.9520.31670 from the ElmorLabs discord. Unlike the latest releases, it is WCF based like older versions.
      If it does not help, try v1.2.9520.31670 from the ElmorLabs discord. Other than the latest releases, it is WCF based like older versions.
      Thank you very much emissary42! The ElmorLabs version 1.2.9520.31670 seem to have fixed the problem!
      My CPU is saying thank you too!
      Have a nice day!
