What is "FPSS"? Bug?
  • What is "FPSS"? Bug?
    Is "FPSS" a bug? I thinks its called "FPS", isnt it?
    Which software version are you using? Is this HWinfo widget?
      I use now 1.0.8822.24657. And yes, it is HWinfo widget.
        Should be fixed with the latest test build. You can get it from the WigiDash Channel on Elmor Labs Discord server.
