Hello Users,
I've been using a SSD device since nearly one year.
It is a G.SKILL Model=FM-25S2S-115GBPE, FwRev=4.2
But since ca. 3 months I have the issue with starting my Operating System.
In fact sometimes I have to press up to 20 times on the Powerbutton to start U10.04.
-- in the beginning of the day --
Start: I press the Power Button .. then the Notebook shows the Bios Logo
and at this point nothing is going on .. (The Harddrive LED shines steady)
so I hold the Power Button for several seconds and the Notebook goes off
then I go to Start
and this repeats on and on until (The Harddrive LED blinks) and Ubuntu boots ...
--- end --
If I wait for ca. 20-30 seconds after one press on Power Ubuntu beeps and print:
Error 0200 Failure Fixed Disk 0
Error 2110 HD00 Hard Disk Drive Error
Press F1
Furthermore important to say ist that if I reboot between short times for example in 2 minutes the system starts immediately.
The good thing is U10.04 starts always but the many attempts are annoying
But I had not used trim on U10.04 because the kernel doesn't support trim.
Since few days I 've installed a newer kernel and I trimmed several times succesfully.
Free drive space is up to 20 percent.
What can I do?
then I go to Start
--- end --
Press F1
What can I do?
