Trouble falcon64gb
  • Trouble falcon64gb
    i try to install on a new pc ....
    ok in Bios - start win7 and read the unit - i remove the partition to make a clean installation with win7 that have to create two new partitions but........... never at all --
    i reset the pc but ......... from here windows never see the unit and lock the system -
    i try with another hd sata and i complete my installation -
    after i try to reload the falcon:
    1 bios ok but windows never start with unit connected -
    2 bios ok start with unit disconnected and after i connect it to sata and the pc see a "disk"
    and i can't create new partition ......... nothing -
    i read this forum and i try with hdtune to see something:
    the most important thing i think :
    (C7) Ultra DMA CRC Error Count 221 191 0 49631 warning
    what i have to do????
    Firmware version : 1571
    In this condition i can upgrade the firmware ???
    i can use clean function ?
    please help me - thanks
    tony
    hi,
    you should going to clean the SSD and upgrade to firmware 1916, then 2030.
    please follow the step as the link:
    Falcon 1916 with clean funtion: http://gskill.us/forum/showthread.php?t=5171
    Falcon 2030:http://gskill.us/forum/showthread.php?t=6257
