hello I would like to know before buying a pro GSkill G. Skill SSD 60Gb if it was compatible with my chipset AMD 870 and if he manages the trim with my 64bit Windows 7? because I have a motherboard Asus M4A87TD EVO, thank you in advance and sorry for my English I'm French
Gskill pro compatible chipset AMD 870
sorry but finally I have big problem:
I just put my ssd in my pc then I had to format using Parted Magic.
Can I change in bios AHCI mode for the SSD and I start installing Windows 7.
After installation I noticed that my normal hard drive HDD 500GB SATA 2 does walk more so I returned to the bios IDE but nothing to help me! thank you
help please
With Gigabyte AMD890 i can set my sata port 0 to ahci or i can select 1-3 to ahci or 4-6 in ahici mod depend what setting you can do on BIOS. Sometime you dont have that choices so all your port will be in ahci, maybe if you select the port where your seagate drive is plug in and put it back to IDE will help but again its depend of what your BIOS can do. You should ask seagate if the drive is okay on Ahci mod.
