OK, I have a Falcon1 and after a large learning curve decided to update the firmware. I first backed up the drive onto a hitachi 250gb drive as a disk image using Drive image XML then just in case I also used clonezilla to make a backup. The FW upgrade went fine (after I actually understood the directions. But now comes the problem, when I try to go from the image back to the drive both programs fail because "the image is larger than the drive". Somehow I now have several MB less than I had before using the clean then upgrading. 4 days and I still can't get my system put back on the falcon drive - any ideas??
oh and for info the actual files were only about 50% if the drives capacity
