hi,
first post but I have been reading a lot of the great advice on here . THanks so much to the folks who take the time to post!
I have a 128GB Falcon 2 and noticed my win 7 install was getting quite laggy so I began to investigate what I could do, made some changes/updates and then benchmarked my drive.
Running AS-Benchmark I see that my 4k read/write is at 20 & 10 respectively. These seem slower than what others are achieving by a long haul.
Other speeds seem ok (I'll post the results up once I get them off my other machine)
My hardware:
Q6600 @3.2GHz
GA-EP35-DS4 m/b - latest bios
6GB RAM in Dual channel mode (@800MHz)
Falcon 2 (on SATA 0 port)
WD Raptors - 15GB and 300GB (on SATA ports 1 & 2)
BR reader (SATA 3 or 4)
AHCI enabled in bios
Falcon f/w is latest available (updated Monday)
O/S: Win 7 Home 64 bit.
SDD partitioned to 3 usable logical drives. OS partition is < half full.
WHat I have done:
Tried wiith C1e enabled and disabled - no change.
imaged SSD, ran parted magic secure internal erase and restored image - no change.
Latest Intel RST driver installed (after trying the drivers from the Gigabyte site for this M/B).
Write cache is enabled.
Have run in IDE mode, with BR drive disconnected (other drives interffering with AHCI mode?? ... didn't try without raptors though) and in Windows safe mode. All no change.
So... is it the benchmark software, a limitation of the P35 boards (ICH9R chipset I think??), or working as intended?
Maybe my win 7 installation is borked?
I'd appreciate some help and advice! I'll get the actual results up asap.
My hardware:
Q6600 @3.2GHz
WHat I have done:
