I have a Falcon II (FM-25S2I-64GBFII) and my data get corrupted (first errors on OS files detected only 2 days after reinstalling Windows 7). Should I RMA it ?
Thanks.
CrystalDiskInfo 3.9.4 (C) 2008-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 [6.1 Build 7600] (x64)
Date : 2010/12/14 21:09:11
-- Controller Map ----------------------------------------------------------
- ATA Channel 2 (2) [ATA]
- ATA Channel 3 (3) [ATA]
+ ATA Channel 4 (4) [ATA]
- FM-25S2I-64GBFII ATA Device
- ATA Channel 5 (5) [ATA]
+ Contr?leur Serial ATA standard AHCI*1.0 [ATA]
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- ATA Channel 2 (2)
- ATA Channel 3 (3)
- ATA Channel 4 (4)
- ATA Channel 5 (5)
+ Contr?leur IDE standard double canal PCI [ATA]
+ ATA Channel 0 (0)
- TSSTcorp CDDVDW SH-S223L ATA Device
+ ATA Channel 1 (1)
- Hitachi HDP725050GLA360 ATA Device
-- Disk List ---------------------------------------------------------------
(1) FM-25S2I-64GBFII : 64.0 GB [0-6-0, pd1] - ix
(2) Hitachi HDP725050GLA360 : 500.1 GB [1-3-0, pd1]
Model : FM-25S2I-64GBFII
Firmware : 2030
Serial Number : DC2110010F1B40035
Disk Size : 64.0 GB (8.4/64.0/64.0)
Buffer Size : >= 32767 KB
Queue Depth : 32
# of Sectors : 125045424
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300
Power On Hours : 30 hours
Power On Count : 9 count
Temparature : Unknown
Health Status : Good (99 %)
Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM
APM Level : ----
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Raw Values (8) Attribute Name
01 0000000000000006 Read Error Rate
09 000000000000001E Power-On Hours
0C 0000000000000009 Power Cycle Count
B8 0000000000000056 Initial Bad Block Count
C3 0000000000000001 Program Failure Block Count
C4 0000000000000000 Erase Failure Block Count
C5 0000000000000000 Read Failure Block Count
C6 00000000137BDE39 Total Count of Read Sectors
C7 0000000007780A2E Total Count of Write Sectors
C8 00000000004332CB Total Count of Read Commands
C9 0000000000125395 Total Count of Write Commands
CA 00000000000E2E85 Total Count of Error bits from flash
CB 00000000000CB8E7 Total Count of Read Sectors with Correctable Bit Errors
CC 0000000000000000 Bad Block Full Flag
CD 0000000000001388 Maximum PE Count Specification
CE 0000000000000001 Minimum Erase Count
CF 0000000000000114 Maximum Erase Count
D0 0000000000000014 Average Erase Count
D1 0000000000000063 Remaining Drive Life
D3 0000000000000000 Unknown
D4 0000000000000000 Unknown
D5 0000000000000000 Unknown
Model : Hitachi HDP725050GLA360
Firmware : GM4OA5CA
Serial Number : GEA534RV14W69A
Disk Size : 500.1 GB (8.4/137.4/500.1)
Buffer Size : 15118 KB
Queue Depth : 32
# of Sectors : 976773168
Rotation Rate : 7200 RPM
Minor Version : ATA8-ACS version 4
Power On Hours : 2860 hours
Power On Count : 442 count
Temparature : 33 C (91 F)
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0000h [OFF]
AAM Level : 80FEh [OFF]
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _16 000000000000 Read Error Rate
02 133 133 _54 00000000008B Throughput Performance
03 121 121 _24 0006013F013C Spin-Up Time
04 100 100 __0 000000000212 Start/Stop Count
05 100 100 __5 000000000000 Reallocated Sectors Count
07 100 100 _67 000000000000 Seek Error Rate
08 100 100 _20 000000000090 Seek Time Performance
09 100 100 __0 000000000B2C Power-On Hours
0A 100 100 _60 000000000000 Spin Retry Count
0C 100 100 __0 0000000001BA Power Cycle Count
C0 100 100 __0 000000000235 Power-off Retract Count
C1 100 100 __0 000000000235 Load/Unload Cycle Count
C2 181 181 __0 002C00100021 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
Thanks.
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- ATA Channel 2 (2)
- ATA Channel 3 (3)
- ATA Channel 4 (4)
- ATA Channel 5 (5)
+ ATA Channel 0 (0)
+ ATA Channel 1 (1)
Firmware : 2030
Queue Depth : 32
APM Level : ----
AAM Level : ----
Firmware : GM4OA5CA
Queue Depth : 32
