Hi there.
I just bought my the SSD last week and a tried to benchmark it. by using HDtuen, the benchmarking curve is not steady with roller coaster result. I also benchmark it by zero erase and update the firmware. I doubt my ssd have some problems. Result are as follow
I am using Win7 64bit with 4G DDR3 10033Mhz of Ram. AMD X250
Reo
Reo
