I have tried to get the 2030 Firmware to open up and have had zero luck. I can get Falcon II 2030 to open into the exe command, but Falcon I 2030 will not. Is there a chance that the file is corrupt or is there something I am missing here?
Firmware 2030 for Falcon I
CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
RAM 12Gb Patriot Viper Xtreme Division-2 DDR3 @ 1908Mhz
PSU Corsair AX 850W
SSD: Intel X25M 80Gb
HD 2x WD VelociRaptors 150Gb in Raid-0
Sager NP8662
CPU: Intel Q9100 @ 2.38 GHz
GPU: GTX 260M @ 612Mhz
RAM: G.Skill DDR3 1066Mhz 4Gb
SSD: Intel X25M 120GbTags: None
Never mind figured it out myself, if anyone else is having issues check this website out http://www.sevenforums.com/tutorials...ve-create.html The firmware is not 64-bit compatible so I just made a MS DOS 98 Bootable USB Drive and got the firmware to work finally! Also my Windows 7 Experience index went from 7.0 to 7.3 just from changing IDE to AHCI and adding Firmware 2030!Last edited by Schwanke78; 11-28-2010, 10:25 AM.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
PSU Corsair AX 850W
Sager NP8662
Bootable ISO with 2030 firmware for FALCON is at http://www.box.net/shared/4m91ckce5y
The firmware is in FALCON/ folder on CD drive.
Already tried bootable ISO, but my WINPE copy was 64bit based. So that's why I just used 98 DOS boot up stick instead.CPU I7-980X @ 3.81Ghz
MB ASUS P6X58D-E
GPU GTX480 @ 770Mhz
PSU Corsair AX 850W
Sager NP8662
