Another possible drive tweak?
  • Another possible drive tweak?
    Hi, i just came across this today, and thought it might be good for us as a tweak, or even on any drive at all.
    not sure if it hasnt been mentioned yet.
    Unnecessary Access Updates
    NTFS automatically updates the last access time and date stamp on folders and files when NTFS traverses its B-tree folder structure. To enhance NTFS performance you can disable this behavior and reduce NTFS's operational overhead without significantly impairing functionality. In the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\FileSystem Registry key, change the NtfsDisableLastAccessUpdate value of type REG_DWORD from the default value 0 (enabled) to 1 (disabled). This Registry value doesn't exist by default, so you need to enter it manually.
    Already disabled
    In Windows 7 x64 on my machine, this value is already set to one (disabled).
    What OS are you using?
    Grits
